fat32 and fat16 hard drive issues
Postby CHRV » 31 Jul 2011, 15:16
All NemoIDE tests is OK on my ZXEVo.
Postby justine » 31 Jul 2011, 15:48
No even running the tests supplied by budder at 3.5Mhz the RND test still fails.
Yet if i go back to the old firware it works ok.
Have you tried with a fat32 drive and created a directory called say JMS then try to rename it to JUSTINE then you reset the EVO and try reading it , the Directory name is corrupted.
justine
Postby CHRV » 31 Jul 2011, 17:47
justine wrote:No even running the tests supplied by budder at 3.5Mhz the RND test still fails.
You flash firmware from my message?
What version is it?
Postby justine » 31 Jul 2011, 17:50
version 31.07.2011 beta
avr 31.12.2010
evo reset 0.42
Revision B Evo
justine
Postby CHRV » 01 Aug 2011, 13:21
Отпишитесь кто еще тестил.
У меня например фикс поправил ситуацию...
Postby DimkaM » 02 Aug 2011, 10:46
Я по английски не понимаю, о чём вы тут разговариваете.
Но у меня с фиксом(до фикса незнаю, хард только что подключил) папочки и .трд создаются и читаются.
Postby CHRV » 03 Aug 2011, 17:11
I set real HDD (Quantum 840AT). It OK.
All budders test is OK.
It work normally with attached configuration:
ide_fix2.zip
(40.76 KB) Downloaded 880 times
Postby justine » 03 Aug 2011, 20:41
Thankyou CHRV that has fixed it. :)
justine
Postby justine » 04 Aug 2011, 20:29
Does the latest version in the google code repositorie have the IDE fix ?
justine
Postby lvd » 04 Aug 2011, 21:34
justine wrote:Does the latest version in the google code repositorie have the IDE fix ?
if you mean rev.477 -- yes, it should have.
