Changes in r672, suggesting improvement
Postby zboszor » 11 Oct 2014, 12:58
I saw r672 and the changes and I had to port it to TSconf. In TSconf, there are 3 more tracked keys already: Left Win, Right Win and Context Menu. Adding them overflows 8 bits in the kb_ctrl_status kb_ctrl_mapped, so a 2-byte array is needed for both functionality. To reduce the AVR code difference between Pentevo and TSconf, I created the attached patch. It also adds the 15th RTC register (may be an invalid change, I don't know) so the extra 3 key states are also exposed.
extra-mapped-keys-rtc-read-pentevo-patch.zip
(2.74 KB) Downloaded 2777 times
zboszor
Postby lvd » 12 Oct 2014, 13:06
for you and co, profit is obvious. what is the profit for us to make your job easier?
Postby zboszor » 12 Oct 2014, 14:51
This patch simply adds the feature to read the LWIN, RWIN and MENU keys. As such, it's a generic feature that programs on the Pentevo can exploit. It's only a plus that it would be a common feature between the AVR code in BaseConf and TSconf with compatible bit layout in the RTC registers.
Perhaps this can be a bridge for restoring goodwill between the two camps, too. I know that I am an outsider and usually the outsider is beaten by both parties when speaking up in a skirmish. I am a hopeless dreamer.
zboszor
Postby DimkaM » 13 Oct 2014, 08:03
zboszor wrote:I am a hopeless dreamer.
Используйте прямое чтение скан-кодов и ваши мечты сбудутся.
Postby zboszor » 13 Oct 2014, 08:42
DimkaM wrote:Используйте прямое чтение скан-кодов и ваши мечты сбудутся.
Funny man. Your comment also implies that you don't agree with the Pentevo r672 change because these are duplicate features:
* - Add reading state of LCTRL,RCTRL,LALT,RALT,LSHIFT,RSHIFT,F12 keyboard states from RTC register D (bits 0-6).
* - Add reading state of NUM LOCK LED from RTC register C (bit 0).
They can be read via scancodes, too.
zboszor
Postby DimkaM » 13 Oct 2014, 14:00
zboszor, если вы умеете программировать под avr и у вас есть свободное время, то попытайтесь избавить ZX-Evo от задержек при чтении регистров RTC.
Тогда я стану счастливым человеком. И многие скажут вам за это - спасибо.
Postby zboszor » 13 Oct 2014, 15:33
That's a good project, indeed. I know how to handle 0% CPU usage signalling from Linux, I hope I can tackle something using interrupts in AVR but don't hold your breath until I work it out. :)
zboszor
