zboszor wrote:I tried the new firmware and ROM. For some reason, when 48K or 128K is selected, my monitor shows a very off screen, either the left border or the bottom border (unfortunately, including some parts of the drawable screen) is not visible. The PENT and 60Hz screens are OK and correctly centered, as usual.
lvd wrote:zboszor wrote:I tried the new firmware and ROM. For some reason, when 48K or 128K is selected, my monitor shows a very off screen, either the left border or the bottom border (unfortunately, including some parts of the drawable screen) is not visible. The PENT and 60Hz screens are OK and correctly centered, as usual.
1. PLEASE don't write bugreports in news topic!
lvd wrote:2. I've tested it with my own monitor and with LCD TV as on video. Other people tested it also with various monitors.
So your problem is most probably monitor issue. Which one you have? Can you try another one, preferably CRT type?
lvd wrote:The only difference between pentagon and 48k raster is different number of lines (320 in pentagon, 312 in 48k raster), 128k adds longer lines (228 3.5 MHz clocks instead of 224) and also changes number of lines (311 this time).
lvd wrote:upd: oh well, where did you take firmware?
zboszor wrote:No idea where the change in the vertical size of the image comes from. Most likely you're right, my monitor is "too new" to support low spec image timings.o
Which monitor model do You have?
zboszor wrote:
I compiled it with the Altera Quartus 9.0 compiler from sources fetched from your SVN repo.
zboszor wrote:I will create a riot here,
lvd wrote:zboszor wrote:No idea where the change in the vertical size of the image comes from. Most likely you're right, my monitor is "too new" to support low spec image timings.o
I use some old CRT monitors. Btw, 48k and 128k rasters are actually not so "lowspec" like pentagon one, since the framerate is slightly bigger (50.08 Hz and 49.36 Hz instead of 48.83 Hz).
lvd wrote:zboszor wrote:I compiled it with the Altera Quartus 9.0 compiler from sources fetched from your SVN repo.
Have you tried first original zxevo_fw.bin along with original zxevo.rom?
lvd wrote:zboszor wrote:I will create a riot here,
So I'll revenge you later, maybe in hell :-)
