ZX Evo native keyboard only is enough to control?
Postby NuClear235 » 13 May 2016, 14:07
When I will control ZX Evo only by native ZX keyboard by 20pin connector. No PS2
How I will switch VGA, BEEP...?
NuClear235
Postby DimkaM » 13 May 2016, 16:25
Изменить прошивку avr. ;)
Исходник здесь:
http://svn.zxevo.ru/listing.php?repname ... current%2F
Postby NuClear235 » 13 May 2016, 16:32
I have no problem, I have just question :-)
Is possible using all functions of ZX Evo just by ZX keyboard without connected PS2 keyboard?
NuClear235
Postby DimkaM » 13 May 2016, 16:51
В стандартной прошивке, нет.
Нужно исправлять прошивку. Обработка клавиатуры в avr. Проблем возникнуть не должно, нужно придумать комбинации кнопок для управления vga/tv/nmi/tape...
Postby DimkaM » 13 May 2016, 16:53
На плате есть разъём nmi, его можно будет использовать как 'Fn'
Postby lvd » 13 May 2016, 17:08
NuClear235 wrote:Is possible using all functions of ZX Evo just by ZX keyboard without connected PS2 keyboard?
currently no.
Postby NuClear235 » 13 May 2016, 23:19
Thank You for answer. I will stay at PS2 keyboard.
I was thinking about new case - get old ZX Spectrum 128 +2 without original electronics
and mount ZX Evo inside it...
NuClear235
Postby NuClear235 » 14 May 2016, 10:47
I have ansver about SVN:
in (root)/docs/ - Revize 709
is lVDs "kbd-map.txt" in V102 - it seems OK.
But above is "kbd-map_s.txt" by user savelij on v103!
And there are some strange changes - LEFT CAPS SHIFT is changed to SYMBOL SHIFT....
Is his version implemented ?
Now is Left Shift still CAPS SHIFT in version 0.57b. (I will hate have on this big key Symbol Shif!)
NuClear235
Postby lvd » 17 May 2016, 16:24
sorry,I haven't understood your question (what is 'jave'?)
Postby NuClear235 » 18 May 2016, 07:46
Sorry, have.
NuClear235
