I have a revision B Evo and i have tried several hard drives ranging from a 40Gb to a 80Gb . I even tried splitting the hard drives up into smaller partitions using fat32 and fat16 but i still have the same problems when using WDC 1.3 final .
The Evo can read the hard drive folders and files i put there with my windows pc no problem, but if i use wdc 1.3 final with the Nemo driver and say i try to rename a folder called "jms" to "jms-test" then WDC shows the folder as a garbage name and so does the Evo when reading it.
The same happens if i try to create a new folder as what i type isnt what appears to WDC or the Evo .
Can someone please help me ?
