fat32 and fat16 hard drive issues
Postby justine » 25 Jul 2011, 21:03
Not sure just formatted with windows. What should they be to be compatible ?
justine
Postby savelij » 25 Jul 2011, 21:21
Пока даже не знаю что сказать. Если отформатированно windows то таких проблем не было. Тем более на вновь отформатированном разделе. Не сталкивался с такой проблемой.
Postby justine » 26 Jul 2011, 10:33
Does someone have a basic program with some code that will write so many sectors direct to the hard drive then read them back to check my ide interface is ok ?
justine
Postby Budder » 26 Jul 2011, 14:57
justine wrote:Does someone have a basic program with some code that will write so many sectors direct to the hard drive then read them back to check my ide interface is ok ?
TESTNEMO.zip
(1.93 KB) Downloaded 611 times
this little test uses only one sector on HDD (master). In cycle test writes to sector 2 data and then check it.
P.S. Use all tests from SCL image. If this test does not find errors, I'll do a more complex...
Postby justine » 26 Jul 2011, 16:25
Thankyou Budder , i'll run them tests now and let you know how i get on.
justine
Postby justine » 26 Jul 2011, 16:30
No errors shown on any test it just finishes and show big zeros on the screen and gives a menu to try again etc.
The last test rnd shows 32697.
Hope this is right ?
justine
Postby Budder » 26 Jul 2011, 17:11
justine wrote:The last test rnd shows 32697
it seems, writing works incorrect.
32697 - is a count of bad bytes... Probably problem in hardware...
"TEST#RND.B" uses 512 bytes from Basic48 rom page (offset #0000) as a testing data...
Postby justine » 26 Jul 2011, 17:12
So i have a fault Evo : ( ??
justine
Postby CHRV » 26 Jul 2011, 17:31
justine wrote:So i have a fault Evo : ( ??
No this bug in configuration. I have this problem too.
Postby justine » 26 Jul 2011, 17:34
Thankyou CHRV i thought i had a faulty Evo or i was going mad lol
justine
