Custom Rom
Postby justine » 03 Jan 2012, 21:21
So am i right in thinking that i make a 16k rom image then i make one big 64k image like
copy /B /Y ff.rom+ff.rom+ff.rom+test.rom custom.rom
The ff.rom just being 16k of $ff and the test.rom being my 16k code .
Then upload custom.rom using the custom rom updater ?
justine
Postby lvd » 03 Jan 2012, 22:47
Justine, it seems OK. If nothing works, probably you should try runing your code from RAM first?
At the same time, you can start trying simple things in ROM, like, for example, border colors changing.
Postby justine » 03 Jan 2012, 22:49
Do i also have to put $00 $C9 at 3D2F as well in the 16K custom rom ?
I have made several 64k roms with various code but none execute i just see vertical lines.
What am i doing wrong ?
justine
Postby savelij » 03 Jan 2012, 23:03
Код $00,$С9 должен быть только в сервисной странице. Через этот код производится вход в custom rom. Custom rom должно выглядеть вот так.
$0000-$3FFF
$4000-$7FFF
$8000-$BFFF
$C000- ваш код
$FD2F - $00, $C9 обязательно
Postby justine » 03 Jan 2012, 23:32
Ok so i first make the 16K custom rom using this code.
      .org $0000
                di
                ;Black ink, white paper, no flash, no bright
                ld a,00111000b
                ld hl,22528
                ld de,22529
                ld bc,767
                ld (hl),a
                ldir
                ld a,1      ;A = pattern value to fill the screen with.
                exx
                ld bc,00feh ;C' = port FEh to write border color into.
                ld e,0      ;E' = number of color to show on border.
                exx
BucPrincipal    ld hl,16384
                ld de,16385
                ld bc,6143
                ld (hl),a
                ldir        ;Fill the screen with pattern
                exx
                out (c),e   ;Indicate what bit is on by changing border color.
                inc e       ;Prepare next color.
                exx
                ld bc,0effeh
EsperarASoltar  in e,(c)
                bit 0,e
                jr z,EsperarASoltar   ;Wait until 0 is not pressed.
                jp Retardo               ;Software debounce loop
EsperarAPulsar  in e,(c)
                bit 0,e
                jr nz,EsperarAPulsar ;Wait until 0 is pressed.
                rlca                 ;Rotate A, so pattern shows next bit.
                jr nc,BucPrincipal   ;If we have completed a turn over A register...
                exx
                ld e,0               ;... Reset E' to 0
                exx
                jr BucPrincipal
      halt
Retardo      ld hl,0
BucRetardo      dec hl
                inc h
                dec h
                jr nz,BucRetardo
      ret
   ; Fill rest of rom with $FF
   .FILL $3D2F-$,$FF
   .ORG $3D2F
   .BYTE $00
   .BYTE $C9
   .FILL $4000-$,$FF
        .END
Then i will compile using tasm and next i will issue this command to build the 64k rom image
copy /B /Y ff_16k.rom+ff_16k.rom+ff_16k.rom+test.rom custom.rom
I then use the custom rom updater and select custom rom using key G. Next i push F12 to reset but i only get vertical bars nothing happens.
What have i got wrong ?
justine
Postby lvd » 04 Jan 2012, 07:38
justine wrote:What have i got wrong ?
justine wrote: jp Retardo ;Software debounce loop
justine wrote:Retardo ld hl,0
BucRetardo dec hl
inc h
dec h
jr nz,BucRetardo
ret
Is it a trolling? :-D
Postby lvd » 04 Jan 2012, 07:41
btw, I don't see where you configure stack and RAM page for it.
Postby savelij » 04 Jan 2012, 10:19
Я конечно извиняюсь, но custom rom прошивался не туда куда производился сброс. Исправил эту проблему. Версия 0.48b.
И написал простенький тест с переключением экранов. Исходник прилагаю. И прилагаю сам custom rom уже собранный.
custom.zip
Собранный custom rom с тестом
(998 Bytes) Downloaded 1013 times
Source.zip
Исходный текст
(1.4 KB) Downloaded 933 times
zxevo.zip
Исправленный Evo Service
(227.1 KB) Downloaded 914 times
Postby justine » 04 Jan 2012, 17:17
Thanx savelij i will try that when i get home tonight.
justine
Postby justine » 04 Jan 2012, 20:18
savelij what assembler do you use ??
I am trying to compile justine.a80 with asw but keep getting errors ?
justine
