ps2 code help request
Postby justine » 22 Jan 2012, 18:23
Could someone help me by making a routine that when called would read the PS2 keyboard and output in A either the ASCII character or any other keys like F1 , F2 etc and these would have a value of 128 + .
And provide the keyboard map with values.
Many thanx in advance
justine
Postby Budder » 23 Jan 2012, 10:38
here is my PS/2 handler, that i use in WildCommander: http://zx-evo-fpga.googlecode.com/svn/branches/tslabs/pentevo/soft/WC/source/003!%20%20%20PS2P.ASM
for use: just add CALL PSD2 at Interrupts.
and use this code for init (at the start):
        LD BC,#EFF7,A,#80:OUT A;also see specs for this port!
        LD BC,#DFF7,A,#F0:OUT A
        LD BC,#BFF7,A,#02:OUT A
if you need get char (like 0-9/)-!,a-z/A-Z): use CLAvA function.
for specific keyz (like F1-F12/TAB/cursors): use dedicated functions (UPPP,DWWW,...,ESC,F1-F10 etc). also see source code.
P.S. PS/2 module is not finished yet...
Postby justine » 23 Jan 2012, 19:21
Thanx Budder :ura:
Having comments in English really helps me understand how these routines work.
justine
Postby justine » 25 Jan 2012, 16:57
I am trying to make my own PS2 routine that should read a value from the buffer and return with the value in A. At the moment i am using my PUTCHAR routine which display an character on screen who's input is in A . But i dont see any character changing on screen. Later when this works i will start on decoding the values to key presses.
Can someone look at this code and see what i am doing wrong , why i get no values in A each time call READ_BUFFER .
PENT_CONF   EQU $EFF7
CMOS_ON   EQU $80
CMOS_OFF   EQU 0
CMOS_SET_ADR   EQU $DFF7
CMOS_RD_WR   EQU $BFF7
; Out A - Key value
READ_KEY   LD H,$0C
      CALL READCMOS         ; 0X0C CMOS
      SET 0,L            ; 0=1
      CALL WRITECMOS
      LD HL,$F002         ; Enable PS2 keyboard
      CALL WRITECMOS
READ_BUFFER   LD H,$F0         ; Read key buffer
      CALL READCMOS
      AND A
      JR Z,READ_BUFFER
      INC A
      JR Z,READ_KEY         ; FF
      ; Out Value in A
      RET
;  In H - Address of cmos register. In L - Data from register
READCMOS        DI
                PUSH BC
                LD BC,PENT_CONF
                LD A,CMOS_ON
                OUT (C),A
                LD BC,(CMOS_SET_ADR)
                OUT (C),H
                LD BC,(CMOS_RD_WR)
                IN L,(C)
                JR OFF_CMOS
;  In H - Address of cmos register. Out L - Data to register
WRITECMOS       DI
                PUSH BC
                LD BC,PENT_CONF
                LD A,CMOS_ON
                OUT (C),A
                OUT (C),H
                LD BC,(CMOS_RD_WR)
                OUT (C),L
OFF_CMOS        LD A,CMOS_OFF
                LD BC,(PENT_CONF)
                OUT (C),A
                POP BC
                LD A,L
                AND A
                RET
Thanx Guys.
justine
Postby DimkaM » 25 Jan 2012, 17:30
PENT_CONF   EQU $EFF7
CMOS_ON   EQU $80
CMOS_OFF   EQU 0
; Out A - Key value
READ_KEY   LD H,$0C
      SET 0,L            ; 0=1
      CALL WRITECMOS
      CALL WRITECMOS
      CALL READCMOS
      AND A
      JR Z,READ_BUFFER
      INC A
      JR Z,READ_KEY         ; FF
      ; Out Value in A
      RET
READCMOS        DI
                PUSH BC
                LD BC,PENT_CONF
                LD A,CMOS_ON
                OUT (C),A
                LD BC,CMOS_SET_ADR
                OUT (C),H
                LD BC,CMOS_RD_WR
                IN L,(C)
                JR OFF_CMOS
WRITECMOS       DI
                PUSH BC
                LD BC,PENT_CONF
                LD A,CMOS_ON
                OUT (C),A
                LD BC,CMOS_SET_ADR
                OUT (C),H
                LD BC,CMOS_RD_WR
                OUT (C),L
                LD BC,PENT_CONF
                OUT (C),A
                POP BC
                LD A,L
                AND A
                RET
Postby DimkaM » 25 Jan 2012, 17:34
PENT_CONF EQU $EFF7 ;ld bc,PENT_CONF
PENT_CONF WORD $EFF7 ; ld bc,(PENT_CONF)
Postby justine » 25 Jan 2012, 18:14
I must be doing something wrong ??
I corrected the silly mistakes as pointed out by DimkaM but i still get nothing.
All i want is a routine i can call that will read a byte from the ps2 buffer then store the value in A .
And i call it again i will get the next byte etc and it must clear the buffer when full once all data is read out.
justine
Postby lvd » 25 Jan 2012, 19:28
justine, you should then take alasm with sts, compile and step your code on real machine.
Postby Budder » 26 Jan 2012, 01:08
justine, why you use opening/closing ports every CALL? for what reason?
added INIT function:
PENT_CONF   EQU $EFF7
CMOS_ON   EQU $80
CMOS_OFF   EQU 0
      ORG #6000
      CALL INIT
      CALL READ_KEY
      CALL PRINT_CHAR;put here your print function
      CALL TERMINATE
      RET
;opening CMOS ports:
;(you should do this ONCE!)
INIT      LD BC,PENT_CONF
      LD A,CMOS_ON
      OUT A;=OUT (C),A
      HL,$F002;      write #02 to #F0
      CALL WRITECMOS
      RET
TERMINATE   LD BC,PENT_CONF
      LD A,CMOS_OFF
      OUT A
      RET
CLEAR_BUFFER   LD HL,$0C01;
      CALL WRITECMOS
; Out A - Key value
READ_KEY
;LD H,$F0
;CALL READCMOS         ; 0X0C CMOS
;SET 0,L            ; 0=1
;CALL WRITECMOS
;LD HL,$F002         ; Enable PS2 keyboard
;CALL WRITECMOS
      CALL READCMOS
      OR A
      JR Z,READ_BUFFER
      CP #FF
      JR Z,CLEAR_BUFFER
;INC A
;JR Z,READ_KEY         ; FF
;Out Value in A
      RET
READCMOS   PUSH BC
;LD BC,PENT_CONF
;LD A,CMOS_ON
;OUT (C),A
                LD BC,CMOS_SET_ADR
                OUT (C),H
                LD BC,CMOS_RD_WR
                IN L,(C)
      POP BC
                RET; JR OFF_CMOS
WRITECMOS   PUSH BC
;LD BC,PENT_CONF
;LD A,CMOS_ON
;OUT (C),A
      LD BC,CMOS_SET_ADR
      OUT (C),H
      LD BC,CMOS_RD_WR
      OUT (C),L
;OFF_CMOS   LD A,CMOS_OFF
;LD BC,PENT_CONF
;OUT (C),A
      POP BC
      LD A,L
      OR A
      RET
Postby justine » 28 Jan 2012, 20:27
Budder If i get you right , i call INIT once then i call READ_KEY which outputs the value in L and the do LD A,L and call my PUTCHAR routine which takes A as the input. I only call TERMINATE once i have finished reading the keyboard ?
justine
