jp (hl)
Postby justine » 23 Mar 2012, 19:11
Is there a way if i use JP (HL) in a routine to allow me to use RET in the routine that was jumped to ??
For example :
LD HL, TEST
JP (HL)
; Routine continues here
; This is the TEST routine
; Code to do stuff and then
RET ; Return to the line after the JP (HL)
Is this possible ???
Thanx
justine
Postby нолька » 23 Mar 2012, 19:30
Postby DimkaM » 23 Mar 2012, 19:41
JP (HL) worked as LD PC,HL
   LD HL, TEST
   JP (HL)      ;PC=HL
TEST   go code
Postby justine » 23 Mar 2012, 19:49
No what i need is a way to make a do the following with a command that doesnt exist. CALL (HL) now i know you can use that command but surely there is a way using JP (HL) so that when the called routine issues a RET it jumps back to the next command line after the JP (HL) was issued ??????
justine
Postby DimkaM » 23 Mar 2012, 19:57
   ld a,3
   call go_func
go_func      ;a-number function
   add a,a
   ld hl,tabl_func
   add a,l
   ld l,a
   jr nc,l1
   inc h
l1   ld a,(hl)
   inc hl
   ld h,(hl)
   ld l,a
   jp (hl)
tabl_func
   dw func_1
   dw func_2
   dw func_n
func_1
   ret
func_2
   ret
func_n
   ret
Postby lvd » 23 Mar 2012, 20:03
ld hl,RETURN_PLACE
push hl
ld hl,JUMP_PLACE
jp (hl)
RETURN_PLACE  ;here we will return by ret
Postby lvd » 26 Mar 2012, 14:22
TS-Labs wrote:
call $+3
jp (hl)
You are stupid lamer. RET from a procedure will return to jp (hl).
Users browsing this forum: Google [Bot] and 9 guests
